Re: what did I do! Engine not starting
Leon Swarmer /
Sorry, but the three pad things are not the problem.
Those are bits of the clutch assembly. When your engine is running and you rev it a bit they slide outward and start to grab the Inside of the outer circle and take you down the road.
They shouldn't touch unless you are spinning the engine more than idle speed.
I don't know your bike to give you better help... but that's not your problem.
Leon
