Re: smoky ped
Robert Fosdick /
sometimes 2-stroke burns grey. if you had a dramatic loss in power i would suspect the piston rings especialy if you have a big bore kit and even more so if it has been put in recently. i highly doubt its a gearbox seal. but i have been wrong before. but i would pull the head first off, for its pretty easy to do and if that is your culprit you will know right away
