Re: smoky ped
Ray West /
I am not going to speculate to what the problem is, I am just here to state the it would be very possible that it is ATF, and bassman ATF doesn't have too far to go to get to the motor, there is only one seal on the clutch side seperating the bottom end(ATF) from the top end(crankcase), there should be one other seal between the case halfs that is also the only barrier between the crankcase and the tranny
If a seal went you will be tearing the motor down, but wait around for the Tomos experts.
