Re: 1980 Motobecane runs like dream until.....rest
Matthew Westberg /
I had the same problem with the magneto cover until just recently.
What I do to get the Magneto cover off is use the "Inertia Trick".
First of all, get a plain old 3/8ths socket wrench (the most common size) and a hammer. The square head on a 3/8ths wrench fits quite well into the sqare hole, making a more than acceptable substitute. Now, look at the magneto cover, you can see that there's two peices: the main cover and the small central plate (with the square hole). Use a utility knife to make a small scratch mark that runs across the edge where they overlap (this is so you can see if you're making progress and let's you know how close you are to the original position when you put the cover back on).
Now you want to insert your socket wrench into the square hole. KEEP IN MIND: This is a _reverse_ thread and will loosen by turning clockwise not the otehr way around! What you want to do is use the hammer to whack the end of the wrench handle quite hard. Due to inertia, the central plate will (in most cases)be knocked loose a bit (you should see the line you marked split as the two pieces of the cover separate)keep hitting the wrench as needed, but after a few whacks you should be able to simply unscrew the centre plate by hand and take the main cover off (it contains the large magneto magnets, so don't worry about it sticking, just pull away).
When replacing the magneto cover, besure you line up the cover's two small bumps (inside the main cover plate with the magnets) on the two small dents on the hub of the cam.
  1980 Motobecane runs like dream until.....restartTopic by: Brandon Henry Brandon Henry 08/04/04 04:10PM
  Re: 1980 Motobecane runs like dream until.....restRe: Joe Woods Joe Woods 08/04/04 06:00PM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/04/04 06:36PM
  Re: 1980 Motobecane runs like dream until.....restRe: Joe Woods Joe Woods 08/04/04 06:50PM
  Re: 1980 Motobecane runs like dream until.....restRe: Matthew Westberg Matthew Westberg 08/04/04 07:40PM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/04/04 07:46PM
  Re: 1980 Motobecane runs like dream until.....restRe: Joe Woods Joe Woods 08/04/04 08:17PM
  Re: 1980 Motobecane runs like dream until.....restRe: See Ya Moped Army See Ya Moped Army 08/04/04 07:50PM
  Re: 1980 Motobecane runs like dream until.....restRe: Dan Adams (50:1) Dan Adams (50:1) 08/04/04 09:05PM
  Re: 1980 Motobecane runs like dream until.....restRe: Matthew Westberg Matthew Westberg 08/04/04 10:55PM
  Re: 1980 Motobecane runs like dream until.....restRe: Matthew Westberg Matthew Westberg 08/04/04 11:06PM
  Re: 1980 Motobecane runs like dream until.....restRe: Joe Woods Joe Woods 08/05/04 02:36AM
  Re: 1980 Motobecane runs like dream until.....restRe: Matthew Westberg Matthew Westberg 08/05/04 01:38PM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/04/04 09:07PM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/04/04 09:09PM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/05/04 07:23AM
  Re: 1980 Motobecane runs like dream until.....restRe: A.A. Ron A.A. Ron 08/05/04 07:21PM
  Re: 1980 Motobecane runs like dream until.....restRe: Dan Adams (50:1) Dan Adams (50:1) 08/05/04 08:57PM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/05/04 08:06PM
  Re: 1980 Motobecane runs like dream until.....restRe: Robert Fosdick Robert Fosdick 08/06/04 09:44AM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/06/04 05:55PM
  Re: 1980 Motobecane runs like dream until.....restRe: Leo Heyman Leo Heyman 08/07/04 08:53AM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/07/04 11:42AM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/09/04 10:50PM
  Re: 1980 Motobecane runs like dream until.....restRe: Dan Adams (50:1) Dan Adams (50:1) 08/10/04 12:34AM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/10/04 12:51AM
  Re: 1980 Motobecane runs like dream until.....restRe: Brandon Henry Brandon Henry 08/10/04 02:59PM
  Re: 1980 Motobecane runs like dream until.....restRe: Dan Adams (50:1) Dan Adams (50:1) 08/10/04 06:52PM
