No power
I finally got the timing and idle adjusted on my tomos bullet so it runs ok, but it doesn't drive the wheel. Does anybody know if clutches can go bad, or is it possible to remove and clean them so they might work again?
thanks for any help.
Bud
Re: No power
Clutches can go bad and you will need to drain the transmission fluid before you take the cover off. Also, it helps to have an impact wrench to remove the clutches.
