Re: Sparta needs only minor help!!!
Jake Van Order /
I'll agree with that. I recently picked up a Balboa that was smoking like a chimney. I switched it out for Gianelli and the smoke is gone. I figured it was that because I use Motul 600 which is pretty smokeless.
Try cleaning your exhaust. I like to use MAP gas, burn it out and then tap out the carbon. On most Sachs exhaust, you can take off the rear cone and tap out the baffle.
Good luck
--jake
