broken '77 puch maxi sport
My moped died in the middle of a ride the other night and I can't figure out what's wrong with it. When I pull the compression lever the engine doesn't turn over at all. When we originally got the moped up and running it was unusually loud. I was told that it was a problem with the bearings. Any chance these problems could be related?
Re: broken '77 puch maxi sport
Jason Luther /
did your motor seize? does the motor turn at all? any number of tings could have happened.-jason
Drain your trans fluid and run a magnet thru fluid,, if you have metal larger then fiber shavings, you have ether a clutch or crank issues,
also, pull the head check dome for metal burns/pitting from Rings
