broken piston ring
I have a targa lx and I broke a piston ring today and I was wondering how long I can run it with only one ring? (The piston needs replaced anyhow)
Re: broken piston ring
u can run it for awhile but u should replace it asap. ive been running my puch with only 1/2 of a ring for about a week
depends on how it broke..
if it broke while the engine was running, who knows what other damage was done.. may as well get in there and look.. Leaving a part of a ring on a piston is inviting disaster since the ring segment can migrate over to a port, get hung up and trash both the piston and cylinder.
If you broke it while working on the engine, you can run on one ring.. i have about 200 miles on one ring since my bottom ring snapped while installing the piston a few weeks ago. I'll put another ring on during the next major tune-up..
Racers often used only one ring to reduce friction, sacrificing some piston cooling in the bargain. So generally it's not recommended..
Jason Baker /
I broke while slidding the cylinder over the piston and I took the pieces off.
