horn and light kills engine
When ever I have my lights on or my horn pluged in my moped wont start or if it does it will die soon after. Whats going on!
Re: horn and light kills engine
It sounds like you have a short Circuit...check all your wires make sure none of them are touching the frame, or handle bars. if you have any disconnected wires cover them with tape. Then check to see if any wires are melted looking.
Ben Van Zoest /
What brand moped?
Jason Baker /
1995 Tomos targa lx
Ben Van Zoest /
Ok, I looked at several different Puch schematics the Bombadier assembled Maxi's print shows with clarity that IF the horn is internally shorted zero Ohms the horn magneto coil output which is shared with the ignition circuitry grounds the coil output, hence no run. To confirm I just looked at my Maxi I bought used recently, the slip-on connectors where taped together one has 2 green wires the other 2 wires blue and blue/black. I removed the horn and it was shorted. Were I live no one gives a crock about the horn not even a lic. plate etc. Lucky me.
Jason Baker /
same here LOL
Hey i have a Tomos Targa LX that is 1995, and i can't get it to start at all, When i peddle you don't hear anything like there is no compression, i mean the Spark plug looks fine but i don't know if like the engine is bad or what, if anyone can help that would be great.
