Profile of a new (Gloria Intramotor Minarelli V1)
Profile of a new Moped owner (and subsequent mechanic)…PLEASE READ!!!
Muchos Gracias!
1974 Gloria IntraMotor Blanco
2.2 HP Minarelli V1 Engine
1. History –
You can skip this and read important stuff, like 2.
My dad brought home a Moped that cost him $30! CAD! Wasn’t running, here’s what we did…
We cleaned the carb, checked fuel flow/spark. Would run only if we put gas in the carb and would die out once that was burned off. Finally, we added a gasket (cereal box) and tightened the bolts that hold the carb to the engine. It worked pretty well!
We drove it a while, oil began leaking out of all the bolts holding the crankcase, which we discovered were a mix and match of different lengths and sizes. I also discovered there was NO bolt in several of the holes, only some unidentified goo covering up a small twig that was jammed in.
2. Present Problems/Questions (in order of importance!)
Re: Profile of a new (Gloria Intramotor Minarelli
O.K.......definitely get the bolts that u need and repalce the "sticks" that your pops put in there. Next,...your chain should have about 3/4"-1" of total play at a point half way between the 2 sprockets......as for the "skipping" it sounds like it is slipping a tooth, which could be caused by under/over tightening of the chain. if something is bent, then keep checking ebay or something to get the parts u need......oh yeah,....the bolts should be able to be found at just about any hardware store.......and try to get a manual for your bike!....it's the best tool in your shop.........hope this helps u....filley
