puch horn?
Troy Brown /
I think i hooked up my horn wrong . it wont stop running running
Re: puch horn?
you mean the horn wont turn off
what moped are you talking about
it helps us alot if we get lots of info
check the horn switch, if you take the light/horn switch off the handle bars does it turn the horn off?, if so put ssome electrical tape under the switch so the solder does not ground itself to the metel bars
try checking the wire connector at the right side of the ped(view when sitting on ped)
like i sed we need more info to help.
Re: puch horn?
Troy Brown /
tbrd OP
sorry about that. its a Puch Maxi if that can narrow it down.
Re: puch horn?
Ben Van Zoest /
cut the blue/black feed wire to the horn, if it stops buzzing more than likely you have a bad switch. Brown is chassis ground.
Re: puch horn?
Troy Brown /
tbrd OP
thanks .
Re: puch horn?
Jason Luther /
sometimes the horn on my bianchi sticks on, its just the button sticking. take the switch cover off, move it around a bit and tighten it back down. always works for me. i wouldnt just cut wires. unplug them maybe...-jason
Re: puch horn?
I'm not 100% sure you should go cutting that wire, I believe that Puchs must have the horn hooked up to run
Re: puch horn?
Ben Van Zoest /
Brown ground wire yes the other is just a feed wire N/O. I was only suggesting to cut the wire to isolate the problem! AND who uses the buzzer anyway?
Re: puch horn?
yea a puch must have the horn plugged in to run
Re: puch horn?
but you could just bypass it
but its better to find the correct problem and fix it the right way
a job well done will last allot longer than a job done in a few minutes
but remember
"if you can't duck it, Fuc it"
hehehe
Re: puch horn?
a quote from the duck tape
Re: puch horn?
Troy Brown /
tbrd OP
I did bypast it so i could test ride it. i will go through it again later in the week.
I want to know that everything works and hooked up right, then i,ll take it off
