Headlight only comes on when i use the brakes
Jeff Stutz /
On my tomos the headlight only comes on when i hold in the brakes real hard. Is it grounded to the breaks or something. Any help is appreciated
Re: Headlight only comes on when i use the brakes
i would check all of the lighting circuit wires
maby there is a cut wire somewhere then when you pull on the brake lever the brake cable flexes and pushes the wire against your frame grounding it off and turning on your light
also i would put some tape under the switches because the solder may be touching the frame
Or your moped has been wired incorrectly and the headlight is hooked up to the brake wiring.
Jeff Stutz /
jeff OP
I didnt touch anything in it though, Sat for about a month then when i went to fire it up no headlight.... Although i do not have a flasher.....
