Re: Dim lights on Gloria Intramotor (Franco Morini
Don Ohio /
Check the ground on the headlight.............the connection from the SIDE of the bulb base. Also,that probably takes a 6 volt,18 watt or up to 21 watt headlight bulb. Now disconnect the horn wire and try it again. Sometimes the horn connection at the switch would stick, robbing power from the headlight.
don-ohio
