Re: Dim lights on Gloria Intramotor (Franco Morini
Edward Edwards /
I have a moped that when I first got it the brake light was on all the time and when I applied the brakes it would go out. the problem was the wrong brake switch, it should have been a normally closed (N.C) instead of a normally open (N.O). The headlight was dim because the wiring under the insulation turned to a green powder. I replaced the wire and it's OK.
