Re: spree dont start
Ziggy F /
If you don't have good compression there is no suction to get fuel into the engine, and spark stays dry.
Is your spark dry?
Put some fuel straight into spark plug hole and try.
Spree is using by-starter thing to help you start, it is attached to carb, if this malfunction that maybe your problem.
Unscrew it and lift this thing a little and try it to kick.
It will run without it if you disconnect it.
Open throttle 1/3 of the turn and kick.
Make sure reeds screws are tight.
