Re: spree dont start
Ziggy F /
Your compression is on low side, that may be your problem.
Maybe you not getting fuel, make sure hoses on carb are in correct order- one is a fuel hose and one is for vacuum.
Make sure they are not reversed (I've seen that)
To check if fuel is getting to carb- unscrew the screw on the bottom of carb, fuel should leak.
Sprees are tricky to troubleshoot, no traditional petcock, CDI dosn't help in troubleshooting process.
