Re: spree dont start
G W /
right after the intake is a thing called a carburator, i have a spree,,, havent looked at it for awhile its broke down,,, bt no reeds on this ppooper,,, all there is,,, head, piston rod crank gaskets gears case intake carb and airfilter, this engine is small,, it dont need reeds,,, someone else correct me if im wrong, but im 99.5% sure you have the term reeds mixed up with something...... take a look at a weedwhacker,,,,check that for reeds .make that 99.9
