Speedo Bulb....
I need a tiny 6volt .6 watt light bulb with a slide bayonet type base for a speedo light...Anyone know of a source for these? Application is a Vespa. It would be nice to see the needle move at night..thanks..
Re: Speedo Bulb....
I was at Radio Shack looking for larger bulbs for my stop lamp but all they had was tiny 6 and 12 volt stuff... all sorts of base types including mini bayonet.
Slide bayonet? A bayonet is pushed in and turned..
lets see.. 6V and .6 watt.
.6 watts = current X 6V
current = 0.1 amps (100 milliamps)
iitem # 272-1115 is close (6.3 V , 150 ma) and its a stock item.
Re: Speedo Bulb....
Frank Garland /
GReat idea...but, it didn't work...the base of the bulb is slightly too large...Still looking...Thanks...
Re: Speedo Bulb....
I need a Tomos Spring speedo light bulb.
12V 10watt - where to find these?
also, is that the correct size? The manual says so.
Thanks.
