clogged muffler
gentlemen-
muffler from my 78 garelli supersport is clogged up. runs fine without it on, but when i put it on it bogs down and stalls out.
i've been soaking it in degreaser and water, hosing it out, putting oven cleaner in it and letting sit, then hosing it out... and yes carbon chunks are falling out but it isn't helping enough.
who knows how to thoroughly clean one? i've talked to a few muffler and radiator shops, but no one is willing to put it in a boil out tank, which we thought would do the trick. so, what kind of toxic, nasty chemicals do i need? would boiling it on the stove in hot water loosen it up?
someone has to have a great solution... thanks
Re: clogged muffler
See Ya Moped Army /
I rod the muffler out like I was cleaning my M16 in the Army. Chemicals will loosen grease but do little to remove carbon.
Re: clogged muffler
Bruce Wilkinson /
Put it in a campfire and let it get orange. That will burn the carbon out.Now that you have soaked it with cemicals there might be a chance of an explosion. This is what is done according to 'Freds Guide to fixing your moped' in the resources section. I did it on my Ciao muffler and it worked. bruce
Re: clogged muffler
on the campfire, good idea... Ryan says we could throw it on the barbecue and toast it that way too... i'll give it a try... and stand back...
Re: clogged muffler
bring it on over dude, i guess we burn it clean
Re: clogged muffler
I'd like to try this myself...but do you have to remove the inside if you try to burn it out?
Re: clogged muffler
Bruce Wilkinson /
NO, just toast the whole muffler. bruce
Re: clogged muffler
crap...forgot to ask will I need to repaint the muffler after doing the roast?
Re: clogged muffler
Bruce Wilkinson /
I repainted mine with BBQ heat paint ( mat black ) bruce
