NP-50MA Cuts Out at Speed
Jim Holcomb /
At 40 kph an slower, my NP-50MA runs great. At 45-50 kph it cuts out. You're going along and it looses power, then powers on again, then looses power, etc. So you have this staccato effect of deceleration/acceleration. It has only about 400 km on it. It worked fine until recently. Any ideas? Thanks.
Re: NP-50MA Cuts Out at Speed
Tab Patterson /
I know mine runs rich and can sometimes do just that. I am looking at ways to open up that airbox. Mine cuts out at 50 to 55kph. It's the way they slowed 'em down.
Jim Holcomb /
jdh OP
Thanks. I wish mine would go that fast before cutting out. Anything over 40 kph and there's the problem. Also, it use to go 50 without the problem.
Tab Patterson /
How many turns out are you running your idle mix screw? I'm at about 2 1/2 turns. Any more than that will make it 4-stroke a bit more on the top end.
Jim Holcomb /
jdh OP
I was out further than that and backed it back to your suggested 2-1/2. But it didn't make a difference. I put a fuel filter on it, which seems to have made it worse. So this makes me suspect it's a fuel problem and I will bite the bullet, pull the carb, and blow it out. Maybe there's a blockage somewhere. Thanks.
