The oil is leaking out of the oil pump. It doesnt leak that much but i ride it alot so it leaks alot of oil. Anyone have any ideas?
Thankz
Taylor
Thankz
Taylor
its a 2005 tomos tomos?. dude that should still be under warranty.....go use ur warranty man...
I am also noticing alot of oil stuck to the bottom of my engine but I thought it might be coming from the exhaust port. Do you think it is from the exhaust or is the oil pump leaking.
maybe the pin that holds on the lines is a little loose and the hose is loose and leaking a tad take of the cover on the sidee
and check possbiltyy.
The leak I think is coming from a little hole under the two pumps
go see the warranty man :)
Nick
