Freewheel
Aj Fitzgerald /
Hello All,
I have a question or problem with my moped I was hoping someone may have some insight on. I believe the problem is the freewheel needs to be replaced but before I go tracking down the parts and order I want to get input from you all to make sure I get everything I need. Also if any of you happen to have the parts I need that would be great.
The problem is when you pedal, the freewheel spins but does not crank the wheel. It just spins freewheel like it does when you back pedal. Essentially the freewheel does not appear to be catching to crank the wheel, thus cranking the motor over. So unless I have a big and steep hill I can’t run the moped, god for bid I get stuck at a flap spot I am screwed. Thanks all.
