Tail light
Does any one know the wattage of the tail light- brake light bulb on a 1985 Yamaha QT50. I just got the $15.00 basket case running but the tail light is really dim. I think I have the wrong bulb but I not sure. Any help would be appreciated.
Bob
Re: Tail light
I bet ur problem is either a weak ground, or weak power connection. check all ur wires and connections for the light. look for warped wires, and corroded connectors. replace warped wire and u can clean up connectors with a wrie brush
