Re: 1980 Honda NC 50 (Express)
Will Percival /
Usually that is a sign of cruddy gas in the carb.. (at least on mine) Drain the carb using the drain screw and see what the gas coming out looks like... When you had the tank emptied to clean the petcock, some rust could have built up in there and found it's way into the carb. Not 100% sure if that is the cause and solution, but it has happened to me before...
