Honda Aero 50 spark no fire
Leonard Torres /
Just picked up yesterday.It is oil injected,it has spark but will not fire up.Carb was cleaned looks good,I dont understand exactly how it works but gas is getting to the carb,cant tell if oil is getting there.There is a electric choke too cant tell if is it working or not.I have a voltmeter and will check when I turn key on.Has electric starter, turns over very easy.What is starting proceedure?Hit start button only?Please Help.
Re: Honda Aero 50 spark no fire
do u have to hold the brake and start it
what kind of moped is it?
Nick
nevermind- it was in the title
nick
Does the bike have a 'kill switch' on it?
If it does, check it out with your voltmeter.
Leon Swarmer /
pull the plug, spray a bit of starting fluid in there. tighten it up connet the wire and hit the starter.
did it run for a few seconds?
yes, You may have a fuel prob
No a spark issue. Did you put in a new one and properly gap it?
Leon
You Said it turns over Easy, You should Check the compression.
-Adam Zich
Leonard Torres /
Thanks for the suggestions,I found out the left brake lever needs to be pressed when starting.Took out my vom and checked for voltage at the electric choke none.still does not start was about to do the starting fluid test ran out of time.Where can I find a wiring diagram or manual online?
