Is it possible to remove the nut inside the transmission 2 peeds of a Puch?
I want to check the first and second speed clutch, but i didn't have the special tools to block the gears to remove the first nut !!!!!
What can i do ???
What can i do ???
If I remember correctly, it's a reverse thread nut. I have the Puch tool to block the gears, so I don't know what else works. I wouldn't use screwdrivers to hold them or you could "screw" something up.
Look at the attachment, and you'll see that you need a special tool to lock it with. You may be able to improvise, but I would suggest getting a puch service manual. It has alot of useful info about overhauling puch engines, including 2 speed models.
Hope this helps,
JF
