Re: pic 2 for real
See Ya Moped Army /
If the motor has a variator it has the rear mounted triangular shaped box. They did not use the side mounted air box on the variator clutch models because when the motor pulls in under load, the carb would interfere with the motors movement. If it's a 50V, it should have the rear mounted air box.
