how do i take this off
how do i take this pully off i see no bolts? look at pic to see what i mean
Re: how do i take this off
ask ziggy
First you have to unscrew the nut at the base of the pedal so that the pin that holds the pedal in place is free to move out. Then gently tap on the pin with a mallet to knock it out (without damaging the threads). The peadal arm should slide off the pedal axel. Then the pulley should slide right off...after you take of the belt of course or youd risk damaging the bearings inside the pulley...
and you can try some penetrating oil if the crank pin is stuck
