Re: Puch Maxi Questions
Jason Luther /
are you talking about the screws that hold the cover on? or something inside? there isnt a gasket, just clean the rust off with a little wd40 sprayed on a piece 220 grit sand paper, and then wipe off the wd40. unless the filter is super dirty and clogged, you shouldnt need to replace it. if you think its clogged take it off for a minute and see if the ped runs better. if you do need one, <www.mopedwarehouse.com> has them for pretty cheap. hope this helps.-jason
