Bing throttle cable removal
Christopher Riddick /
I'm trying to remove the throttle cable form my Bing carb from a 1980 Puch Maxi 2-speed.
I can unscrew it from the curved tube at the top of the carb, but it won't come free from inside the carb.
Any suggestions?
Re: Bing throttle cable removal
You need to take the top off and remove the slide & spring. The cable end is in there and you can pop it out by moving the end over to the slightly larger hole.
BK
Ok, thanks. I'll try it tonight.
Thanks BK-
I got it out. The slide was frozen in the carb, so I had to break out the solvent.
Chris
