Puch 2 speed trans (repair?)
Hi, is it hard to repair the transmission of a Puch Magnum 2 speeds ?
I found i clean Magnum II, motor start Very easy. On the first speed everything is ok, but if i slow down little bit and give gas after, the transmission fall to Neutral !?!?
Samething if i didn't have a second speed gear....
I need to whait the motor run at idle speed and the clutch engage first gear and it run !?
I change the trans oil, i put type F.
The old oil was brown and thick.
Can you help me ?
Re: Puch 2 speed trans (repair?)
try holding in the clutch until the 2nd speed engages. I had unevenly worn clutches and it did that, it's also possible the tab-washer on the clutch cover has come un-tabbed and spins freely.
Josh
#000
