brake cable snap
My brake cable snapped so I fixed it but when I squeeze the brake there is no tension, I mean the part on the wheel does not pull the cable back when I let go. I have it basically so the rear brake is always applied and when I squeeze the level it does stop. It just won't pull the cable so the brake is fully released. Any tips or solutions would be greatly appreciated.
Bigos
Re: brake cable snap
Daniel Mansager /
Did the inner wire snap? or just the outside cover? If the inner wire snapped, you should get a new cable because i don't know if that can be fixed...
Dan
See Ya Moped Army /
Sounds like the inner cable is hanging up inside the casing causing it not to release. The casing may have a bend in it or it is rusty inside. Replace the casing if you already haven't done so.
