hotwire
I tried to hotwire my moped and now i can't get any spark can anyone help?
Re: hotwire
what did you do to "hotwire" it?
Re: hotwire
Ian Jeske /
ige OP
i took the front panel off and connected the 2 wires coming out of the ignition. the engine turns over, but theres no spark
Re: hotwire
Matt Rusiniak /
dont connect em
break em apart
when you connect em you ground it (on most mopeds) just insulate each end apart, i did that to my honda when i lost the key
Re: hotwire
What kind of moped is it?
Re: hotwire
Ian Jeske /
ige OP
I think its called a sundiro. i bought it at a swap meet and didn't make the greatest purchase cuz i didn't know what i was doin then.
Re: hotwire
Jazza Razzza /
can anyone put that in laymans terms, ive had my ped down here in my garage for ages, lost both keys, and the garage say they will charge me
Re: hotwire
my ignition switch has 4 wires. Two get connected and two get disconnected when the key turns..
At first i didnt have a key and the key-switch was ruined anyway, so all i did was remove the whole switch body (from the headlight on a Honda PA50) and separate the two sections of the switch.
The front, metal key-section clips to the plastic rear wiring section. It falls apart into the two sections.
Then i turned the rear wiring section to the "ON" position with a screwdriver and stuck it back into the headlight.. The bike was ON all the time. I didn't need to know what the wires actually did.
Later on i found an ignition with a key on a parts bike from the junkyard.. nice..
Re: hotwire
Jazza Razzza /
ive recently lost the key to my moped, but have had it in my garage for ages, i have managed to hotwire it, bt the handlebars are locked in place, and i dont have the key for the moped, how can i get the bars freed?
cheers
azza
Re: hotwire
Someone's gotta cut the steering lock.. or pick it or.. am i missing something?
Re: hotwire
Jazza Razzza /
how would one go about that, is it regularly eazy??
or can someone reccomend a lock picking tool i can buy?
azza
Re: hotwire
Ben Van Zoest /
You could take the ped to a locksmith may cost up to 89-90$ Yes, they pick it to remove barrel I observed how he did it on a Puch which I had bought w/h keys, making a new key is very time consuming OR you can drill out the entire cylinder and locking pin falls out to unlock fork. I am not clear if you had a key operated kill switch you could replace that with a 10$ aftermarket one.
