Re: Just what I didn'y want to happen!
Gregory Mcintire /
The only way that you can remove the petcock or put it back on is to hold the petcock in its proper position, with respect to up and down, while you turn the nut. The nut is a special nut which has left hand threads on one end and right hand threads on the other. It has to screw onto the petcock at the same time it is screwing onto the tank fitting.
If you turn the entire petcock the brass tube attached to it will be bent all about and destroyed.
And yes, there is a fiber or plastic washer (either will work) between the petcock and the tank fitting.
  Puch Maxi - how to start?Topic by: Allan P Allan P 07/04/04 12:12PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 01:54PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 04:55PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:26PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 05:11PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 05:25PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:27PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/04/04 05:46PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:01PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:11PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/05/04 01:53PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/04/04 11:11PM
  Re: Puch Maxi - how to start?Re: Bill W Bill W 07/05/04 03:59AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 09:31AM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/06/04 11:10AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 03:17PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/06/04 06:08PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 06:29PM
  Re: Puch Maxi - how to start?Re: Chris Paz Chris Paz 07/06/04 10:02PM
  Re: Started but petcock?Re: Allan P Allan P 07/07/04 05:28AM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/07/04 05:44PM
  Re: Just what I didn'y want to happen!Re: Gregory Mcintire Gregory Mcintire 07/07/04 08:43PM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/08/04 05:43AM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/07/04 07:32PM
  Re: Just what I didn'y want to happen!Re: Jason Luther Jason Luther 07/07/04 08:47PM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/08/04 06:47PM
  Re: Patience.........Re: Allan P Allan P 07/08/04 07:33PM
  Re: Patience.........Re: Edwin Johnson Edwin Johnson 07/09/04 07:04AM
  Re: SORTEDRe: Allan P Allan P 07/20/04 05:51PM
