Re: Puch Maxi - how to start?
Chris Paz /
Allan,
This is what the petcock looks like for your Puch. It should come out pretty easily just a little twist at the end. When I pulled my petcock out there was a bit of remanence of a seal. When you put the valve back on use some lock-tight around the threads. When you have the petcock out get a small screw driver out and check the bottom of your tank I found about a 1/4 inch of rust flakes in my tank that had been clogging up my filter. Also I found that the threads on the nut that connect to the petcock thread backwards.
Good luck
- Chris
  Puch Maxi - how to start?Topic by: Allan P Allan P 07/04/04 12:12PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 01:54PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 04:55PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:26PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 05:11PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 05:25PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:27PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/04/04 05:46PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:01PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:11PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/05/04 01:53PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/04/04 11:11PM
  Re: Puch Maxi - how to start?Re: Bill W Bill W 07/05/04 03:59AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 09:31AM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/06/04 11:10AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 03:17PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/06/04 06:08PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 06:29PM
  Re: Puch Maxi - how to start?Re: Chris Paz Chris Paz 07/06/04 10:02PM
  Re: Started but petcock?Re: Allan P Allan P 07/07/04 05:28AM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/07/04 05:44PM
  Re: Just what I didn'y want to happen!Re: Gregory Mcintire Gregory Mcintire 07/07/04 08:43PM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/08/04 05:43AM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/07/04 07:32PM
  Re: Just what I didn'y want to happen!Re: Jason Luther Jason Luther 07/07/04 08:47PM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/08/04 06:47PM
  Re: Patience.........Re: Allan P Allan P 07/08/04 07:33PM
  Re: Patience.........Re: Edwin Johnson Edwin Johnson 07/09/04 07:04AM
  Re: SORTEDRe: Allan P Allan P 07/20/04 05:51PM
