Re: Puch Maxi - how to start?
Bill W /
I don't know if your model has the same wiring as the Puch models that were imported into the U.S. but check to make sure the two wires that go into the back of the horn are connected. It was (is) a common problem on old Puchs that the horn would buzz when starting and running. Make sure these wires have not been disconnected.
Also use an Automotive Electrical contact spray to clean the ground wires (brown?) anywhere they fasten to the frame. Also check the terminal wiring block by the engine area to make sure there are no loose or disconnected wires.
If I remember correctly either the Kreidler or Sachs Prima moped has a similar setup with a combination clutch/decompression cable. If you disconnect the decompression cable, it will be much more difficult to pedal start.
  Puch Maxi - how to start?Topic by: Allan P Allan P 07/04/04 12:12PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 01:54PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 04:55PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:26PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 05:11PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 05:25PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:27PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/04/04 05:46PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:01PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:11PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/05/04 01:53PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/04/04 11:11PM
  Re: Puch Maxi - how to start?Re: Bill W Bill W 07/05/04 03:59AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 09:31AM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/06/04 11:10AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 03:17PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/06/04 06:08PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 06:29PM
  Re: Puch Maxi - how to start?Re: Chris Paz Chris Paz 07/06/04 10:02PM
  Re: Started but petcock?Re: Allan P Allan P 07/07/04 05:28AM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/07/04 05:44PM
  Re: Just what I didn'y want to happen!Re: Gregory Mcintire Gregory Mcintire 07/07/04 08:43PM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/08/04 05:43AM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/07/04 07:32PM
  Re: Just what I didn'y want to happen!Re: Jason Luther Jason Luther 07/07/04 08:47PM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/08/04 06:47PM
  Re: Patience.........Re: Allan P Allan P 07/08/04 07:33PM
  Re: Patience.........Re: Edwin Johnson Edwin Johnson 07/09/04 07:04AM
  Re: SORTEDRe: Allan P Allan P 07/20/04 05:51PM
