Re: Puch Maxi - how to start?
Gregory Mcintire /
Your reasoning is logical but this is not how the 2-speed Puch works. The first gear centrifugal clutch can only come into play when the crank shaft has reached an RPM which equates to several MPH. The second gear centrifugal clutch weights are actuated when the rear wheel reaches a speed of around 15 MPH (depending on the sprocket sizes you have) BUT, the second gear clutch requires that the first gear clutch be engaged in order for it (2nd gear clutch) to engage the wheel to the crank. It is kind of complex but actually a very clever way to deal with the problem of keeping the transmission from shifting back and forth between 1st and 2nd at a certain engine speed.
Some Puch engines have a decompression valve but most don't. It is not necessary, and can cause problems. I would suggest disconnecting the cable going to it. Mine starts fine without a decompressor and I have even raised the compression ratio quite significantly (11.1:1).
  Puch Maxi - how to start?Topic by: Allan P Allan P 07/04/04 12:12PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 01:54PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 04:55PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:26PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 05:11PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 05:25PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:27PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/04/04 05:46PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:01PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:11PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/05/04 01:53PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/04/04 11:11PM
  Re: Puch Maxi - how to start?Re: Bill W Bill W 07/05/04 03:59AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 09:31AM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/06/04 11:10AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 03:17PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/06/04 06:08PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 06:29PM
  Re: Puch Maxi - how to start?Re: Chris Paz Chris Paz 07/06/04 10:02PM
  Re: Started but petcock?Re: Allan P Allan P 07/07/04 05:28AM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/07/04 05:44PM
  Re: Just what I didn'y want to happen!Re: Gregory Mcintire Gregory Mcintire 07/07/04 08:43PM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/08/04 05:43AM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/07/04 07:32PM
  Re: Just what I didn'y want to happen!Re: Jason Luther Jason Luther 07/07/04 08:47PM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/08/04 06:47PM
  Re: Patience.........Re: Allan P Allan P 07/08/04 07:33PM
  Re: Patience.........Re: Edwin Johnson Edwin Johnson 07/09/04 07:04AM
  Re: SORTEDRe: Allan P Allan P 07/20/04 05:51PM
