Re: Puch Maxi - how to start?
Matthew Coles /
What you're describing sounds weird...pictures might help.
There shouldn't be a decompression valve on a Puch. There should be a single cable running from the large black lever to your gearbox. That engages the clutch and lets the pedals turn the engine over. Turn the run switch (there should be one) to run, turn the fuel valve on, pull the clutch lever and pedal. If everything is working properly, the engine should start (might take some choke). If it doesn't, you have a problem(s) somewhere that you need to fix. Check out Fred's Guide in the Resources->Articles section.
  Puch Maxi - how to start?Topic by: Allan P Allan P 07/04/04 12:12PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 01:54PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 04:55PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:26PM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/04/04 05:11PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 05:25PM
  Re: Puch Maxi - how to start?Re: Charlie Bennett Charlie Bennett 07/04/04 05:27PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/04/04 05:46PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:01PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/04/04 06:11PM
  Re: Puch Maxi - how to start?Re: Gregory Mcintire Gregory Mcintire 07/05/04 01:53PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/04/04 11:11PM
  Re: Puch Maxi - how to start?Re: Bill W Bill W 07/05/04 03:59AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 09:31AM
  Re: Puch Maxi - how to start?Re: Matthew Coles Matthew Coles 07/06/04 11:10AM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 03:17PM
  Re: Puch Maxi - how to start?Re: Jason Luther Jason Luther 07/06/04 06:08PM
  Re: Puch Maxi - how to start?Re: Allan P Allan P 07/06/04 06:29PM
  Re: Puch Maxi - how to start?Re: Chris Paz Chris Paz 07/06/04 10:02PM
  Re: Started but petcock?Re: Allan P Allan P 07/07/04 05:28AM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/07/04 05:44PM
  Re: Just what I didn'y want to happen!Re: Gregory Mcintire Gregory Mcintire 07/07/04 08:43PM
  Re: Just what I didn'y want to happen!Re: Allan P Allan P 07/08/04 05:43AM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/07/04 07:32PM
  Re: Just what I didn'y want to happen!Re: Jason Luther Jason Luther 07/07/04 08:47PM
  Re: Just what I didn'y want to happen!Re: Chris Paz Chris Paz 07/08/04 06:47PM
  Re: Patience.........Re: Allan P Allan P 07/08/04 07:33PM
  Re: Patience.........Re: Edwin Johnson Edwin Johnson 07/09/04 07:04AM
  Re: SORTEDRe: Allan P Allan P 07/20/04 05:51PM
