Re: Batavus piston removal
Gregory Mcintire /
The rings don't "break in" to the piston, but rather to the cylinder.
You are correct about removing the circlips to remove the wrist pin. It may be stuck, or may slide out relatively easily. A special puller can be used, but your idea of heating it may work also.
