1967 puch.......cuts out while running
O.K..... I just painted my tank, fenders, and headlight assembly. the bike ran fine before i started. But, now when i put it in gear and head off.......it cuts out unless i depress the clutch lever....then cuts out again when i try to go again.
while i had the bike apart,...i also welded the exhaust tube to the manifold because the clamp doesn't keep it connected for more than a couple of days..............I diagrammed and labeled all of the wires in the headlight assembly before taking it apart.....100% positive it is hooked up properly and tightly......HELP!..........Filley
Re: 1967 puch.......cuts out while running
Joshua Filley /
Well,....I feel like a jackass....I cleaned the carb like i should have done right away.....runs like a champ....duh....must have picked up some crap during the disassembly/assembly. I had a good fuel filter on there, but must have really gunked it up during all of this. Replaced it when i cleaned the carb. Later.....Filley
