peugeot stalls
Matthew Coles /
Mine did the same thing, and I thought it was the condensor too. Spray the condensor with coolant after it stalls. Condensors don't work properly when they get too hot, I guess. So that will tell you if that's the problem. I recommend checking for air leaks first, though. Mine would ride for a while, then just die out whenever I got close to stopping. Turned out I had an air leak where the carb fits on the intake (check by spraying carb cleaner on suspect area while running). It was causing erratic idle too. Once I fixed it with liquid gasket, it ran great and didn't die on me anymore.
