sachs motor
Edwin Johnson /
on the right pedal shaft there is a ??lever that goes around and around ...the manual says its a brake lever but what or how should it be fastened to?? the manual shows the lever but not what it connects to...
Re: sachs motor
connects to connection rod- long metal piece, I have them NOS if you need it.
Re: sachs motor
Ben Van Zoest /
yea, i look at it what does it really do??
Sachs motor w/ coaster brake
Ben Van Zoest /
Now I remember, the lever on/by the right pedal shaft engages like a bicyle coaster brake, pedal back stops the rear wheel. That is if the hand lever brake is disconnected and a solid rod is installed instead. NOT a great idea unless you grew up with this fiture!
