New Shocks
The other day while riding, the rear spring on my moped just popped out of no where and now, the shock that it was mounted on is busted. Now that I'm getting the HD ones from MWH, I have a question. Just so I'm safe, I have to grease the bushings on the new shock right? Also, what type of grease should I use, silcone grease?
Re: New Shocks
first of all i don't know if you need to grease the bushings or not, BUT i do know grease and for the all around best protection you can get use a graphite type grease. expensive and probly a little bit of an overkill but it is the best in my mind.
Re: New Shocks
Just got the shocks and Chris said that no grease is needed but thanks for the input.
