Sachs airbox
I need to fabricate an airbox for my sachs motor. Can anyone send me pics of the inside / outside of the box, specifically of the air intakes and inside where the air filter resides.
Thanks for the help.
Re: Sachs airbox
what kind of sachs is it?
Re: Sachs airbox
Its for a 1975 hercules sachs moped.
Re: Sachs airbox
Ben Van Zoest /
mopedwarehouse sells boxes + filters for 500/505 type engines. about 35$ it would be hard to make yourself.
Re: Sachs airbox
Thanks for the warning about fabrication difficulity, but i'm cheap and i'm up for a challenge.
Re: Sachs airbox
bump
Re: Sachs airbox
There's a pic at www.themopedjunkyard.com.
Thor
Re: Sachs airbox
what is the model name of the bike, because that one on MJY looks nothing like the stock one from my bike, I'll send you pics of mine if you would like
Re: Sachs airbox
I can sell you also. I have tons of NOS sachs parts. Airfilter, case, and endcap for $40.
BK
Re: Sachs airbox
BK, I'll consider your offer. Thanks.
Re: Sachs airbox
Yes, please post a pic of your airbox, or what it needs to connect to.
Re: Sachs airbox
please send me them
Re: Sachs airbox
bump
Re: Sachs airbox
The reason that you will have a hard time fabricating it is because the sachs airbox has the choke built in to it. you will have to make a base that contains a choke, the filter and a pretty schnazzy almost waterproof housing. Hard to do.
Or you can go to sears,a nd get a lawnmower air filter, and duct tape it on. No choke but it'll keep some of the dust out.
and if it gets wet you replace the filter.
