Re: puch keeps fouling plugs
Gregory Mcintire /
You don't mention your brand of oil. Some oils such as synthetic 2-stroke oils work extremely well in so far as not fouling plugs. There are other oils that are quite poor by comparison. Are you using 2-stroke oil?
If it is running clean, i.e. not four-stroking then carburetion (jetting) is not likely to be your problem. That motor should not foul plugs unless something is very wrong, such as an extrememly weak spark, possibly due to timing being way off or ignition components or wiring being defective.
Another possibility is that it could be sucking transmission oil into the crannkcase through the right side crank seal. This could cause plug fouling and would also cause the transmission oil to become depleted. Check your oil level in the tranny.
  puch keeps fouling plugsTopic by: David S David S 06/26/04 01:03AM
  Re: puch keeps fouling plugsRe: Rich Battag Rich Battag 06/26/04 01:23AM
  Re: puch keeps fouling plugsRe: David S David S 06/26/04 02:07AM
  Re: puch keeps fouling plugsRe: Randall F Randall F 06/26/04 02:49AM
  Re: puch keeps fouling plugsRe: Bill W Bill W 06/26/04 03:04AM
  Re: puch keeps fouling plugsRe: Gregory Mcintire Gregory Mcintire 06/26/04 03:08AM
  Re: puch keeps fouling plugsRe: Jason Luther Jason Luther 06/26/04 10:03AM
  Re: puch keeps fouling plugsRe: David S David S 06/26/04 10:38AM
  Re: puch keeps fouling plugsRe: Gregory Mcintire Gregory Mcintire 06/26/04 12:27PM
  Re: puch keeps fouling plugsRe: David S David S 06/26/04 02:43PM
  Re: puch keeps fouling plugsRe: Joe Woods Joe Woods 06/26/04 02:53PM
  Re: puch keeps fouling plugsRe: David S David S 06/26/04 05:04PM
  Re: puch keeps fouling plugsRe: Randall F Randall F 06/26/04 07:18PM
  Re: puch keeps fouling plugsRe: Gregory Mcintire Gregory Mcintire 06/26/04 07:35PM
  Re: puch keeps fouling plugsRe: David S David S 06/26/04 07:49PM
  Re: puch keeps fouling plugsRe: Bill W Bill W 06/26/04 09:07PM
  Re: puch keeps fouling plugsRe: David S David S 06/26/04 10:43PM
  Re: puch keeps fouling plugsRe: Bill W Bill W 06/26/04 11:15PM
  Re: puch keeps fouling plugsRe: Mitch Buchannon Mitch Buchannon 06/26/04 11:41PM
  Re: puch keeps fouling plugsRe: David S David S 06/27/04 02:08AM
  Re: puch keeps fouling plugsRe: Mitch Buchannon Mitch Buchannon 06/27/04 02:59AM
  Re: puch keeps fouling plugsRe: David S David S 06/27/04 11:59PM
  Re: Flandria Bermuda 1976 keeps fouling plugsRe: Eric Harrington Eric Harrington 09/20/20 05:52PM
  Re: Flandria Bermuda 1976 keeps fouling plugsRe: P D P D 09/20/20 06:23PM
