which one where?
may have put the wrong oil in. just wondering where the two stroke goes and where the regular oil goes?
Re: which one where?
Two-stroke engines have to have the oil mixed w/ the gas or injected via oil injection. What do you mean by regular oil? The oil or ATF that goes into the transmission or engine oil for 4-stroke engines?
it is a two stroke but it is oil injected so i was wondering i put the two stroke in the hole right behind the gas hole. also there is another oil spot on the side of the actual engine which i was wondering if that takes regular (4 stroke) oil
