Re: Strange Problem
Joe Woods /
heh.. master of none..
front wheels .. you have brake pads and bearings.. Both are easy to check. If i had to guess i'd suspect a problem with the brake actuator inside or the lever outside the wheel or the cable adjustment.
Bearings that as so bad they wont allow the wheel to turn will have other symptoms as well.. like the wheel makes lots of noise, wobbles on it's axel, and gets hot as hell.
