Re: Strange Problem
Christopher Paquette /
The fuel shut off valve was stuck partially close. that was part of the problem. Alas the problem persists. I cleaned the gas tank filter as well as the actual shut off valve. It needed it... the gas tank is pretty rusted...When i cleaned the carb I just sprayed the jets with carb cleaner, do you recommend using air instead?
