Hello,
I was having idle problems with my Motobecane 50, after I rebuilt(cleaned) the carb the idle is working better but my top speed has reduced 8 mph, I rebuilt it again, same problem. should I see if the points need re-gaped,cleaned and the float in the carb, does the sharp point go down or up in the carb. Any advice would be appreciated!
Thanks
