Re: wow..gimmyjimmy needs help!
Bill W /
If the ped has been setting for awhile and the oil injector has a very tiny slow leak, the muffler and exhuasdt pipe could have a lot of old oil in there. You could try flushing the tailpipe/muffler. I don't know where the adjustment is on that model Trac but start at the carb or intake manifold where an oil line goes in and work back to the oil pump. There should be some sort of a regulator adjustor on the pump or the line going into the pump.
As for the nico patch, roll it up tight and light one end and puff on the other. You might also want to fill it with some forbidden fruit, adds to the experience. Dubee, Dubee, Doo ...
